Ah ok.
When Ty was racing the 449, the FMF out produced the pro circuit pipes. If you want pretty, go Akro. Horsepower is the rate of acceleration, torque is power, the more torque you have, the faster you will pull those gears on the big track. I can build you a TXC511 engine that will compete with the big boys and swap your transmission for a six speed (same ratio, just one more gear). That is the most powerful engine Husky made of the 449s.Glad to see them go to a good home. I can't wait to hear how it does on the dyno. I have heard the 476cc jug will give you torque but no power. I hate how the TC falls on its face at high RPMs. You really need to pick your gearing since the gear box is so short and no power up top. Halls is also cleaning up the heads and making a little more power. Heard the FMF flows well almost as well as the Pro Circuit, but man they are both hideous to look at. I was thinking about the FMF header with my akro and the PCV and go back to the dyno see if I can get a hp or two. My last pull on my 2013 netted 43.89hp with max power around 8000rpm, on a pretty hot day. I can hold my own against 55-60 hp bikes but not on big tracks. Every little bit helps. I have 30hrs of hard riding on my 2013 TC449 and it is still doing really well. winter will be tear down time.
What crank mod are you doing?
mmmm pretty...If you want pretty, go Akro.
This is true. I remember the one you have is pretty wide open. I'm not that loud with my insert, but my friends say they can hear me coming miles away. hahammmm pretty...
I still reckon something was off with that Full Ti EVO system you got a hold of, the ones me and the guys have over here (Akra branded not Husky/Akra) are insanely loud, like loud enough to be the only bike black flagged out of 60 at a track day loud!
along with ear plugs...Make sure APL knows that you are adding 29cc to the combustion chamber.I'm going to price up the 511 jug kit and get a quote from Powerflow for head work.
Any recommendation on someone who reworks these husky heads a lot? or are you just doing your own? Also have you swapped in the transmissions at all yet? Heard a bunch about BMW trans swaps. Not sure if its worth it or not if the power upgrades and trans swap is $2-3K. I'll just wait for the new bikes to come out in buy one of them!
Originally, SpeedBrain created a 480cc over bore kit for the G450x and that evolved into the 478cc 511. It's possible, but by the time you bored and re-plated hassle, you could just buy the upgraded cylinder. 29 cc's doesn't seem like much, but adds 7.46 NM (5.5 FTlbs) of torque and that is significant.Can the 449 cylinder be bored to suit the larger piston?
Hey all,
I now have my SMR 449 going pretty fast with the following:
TC airbox lid
PC5
Full Akra evo system.
Just wondering what's next? :P
What other things can be done to make this bike even quicker?
TC cams?
Port n Polish head?
Injector?
Airfilter?
Cheers,
Kane
You all can get them to that hp? I know you talked about it with a 511 cylinder and piston. As far as it staying a 449 though?Or... you can have ZipTyRacing do the performance rebuild.![]()
