In doing a compression test on my fresh Top End on my Maico 490 I could only get 80 psi out of it as well. I was working on the usual hard to start with the Kick Starter easy to bump start scenario. Since the Bike starts easy bump starting it I bump started it with the compression tester in it just to see what happens. I got 180 psi.
is that kicking with the throttle fully open till the needle quits climbing? if so, yes thats pretty low compression, and it probably wants very small jets with that much blowby/low compression.
