husky jim
Says V309H on the box Jim![]()
That sounds like it! Thanks a bunch! I'm going to modernize my 430 with new reeds, ignition, carb, compression release, and front end.
If you add the vee force reeds, and keep the round slide I suggesting adding the UFO to the bottom of the round slide. It's like adding a ramp for better fuel flow. The bottom of the round slide has protruding edges that act like dams abrupting the flow of gasses. You need to rejet. But once it's rejected its throttle response is so much crisper and cleaner. Add this vee force reed set up, a little porting, the UFO and your 250 isn't a 250 anymore. I've tried everything but the vee force reeds. The 250cc can be a sick bike to ride with a little work.
My '81 cr250 was a sick ride. The engine was ported and I added a reed spacer plus the UFO. The engine was so responsive it like knew your were going to rev it up before you wicked it. It was right there throttle wise with no hesitation.
the inserts for roundslides have mostly proven to be good items..it depends how much money you want to invest, really..
I remember dropping the pilot and main jets smaller. There is less gas needed. I think the UFO makes better use of the gas flow. Thus it's rich without rejetting.
It's no lectron carb for under $40 but it is a improvement with the round slide carb.
the only hit on google for that part number is this thread
