that sucks..so these arent really as tuneable? i know what you are thinking too..why leave the vm unless you are doing a "real" upgrade...like a leccy..What brand of carburetor? There is no replaceable needle jet in the Mikuni or Keihin flat slides, you use different needles.
I just buy a assortment of larger needles and I have main jets from the round slides they should fit?
plus the vm has probably the best throttle "feel" of all the carbs, nice and smooth with a nice clunk. really the one thing i dont like about the lectron.I think you will be disappointed with the flat slide.
you should look inside a lectron..and you would realize a stuffer in the slide of a vm doesnt compare to the way the flat slide lectron is. way smoother..a lectron is taper bored as well if you really want to get fancy...It works the first few times hang in there. Stay with it. Don't forget I use the UFO adapter on the bottom of the round slide. The gas has a smoother flow. You will end up with one or two sizes smaller in the Jets. The UFO makes a big difference in the smoothness of the carbs response.
