Teambowles
Looking for opinions, just did the second oil changes on my 13 te449 and 13 te511. After pulling oil drain plugs both still have quite a bit of super fine junk on the magnets. Not as much as after the first oil change but still there. Second oil change with using the Mobil 1 0w 40, both bikes have about 600/650 miles on them. No big junk on magnets just real fine stuff. Also those 2 damn long filter bolts really suck, both are already starting to round out gotta get new better ones. Update on 511....was running fmf wide open no core, put fmf quiet core in, tps reset, adjusted big brass screw 5 and a quarter turns out from completely closed (matched 449 screw) and flame outs are all gone and it seems to pull harder too. Adjusted chains to where I gave them about 2 fingers of slack on bottom of chain, seems quite a bit tighter than other bikes I've owned but they don't tighten up when you sit on them.
