Throttle on
At 2400 miles on my 15 fe 501s. I experienced my first mechanical/ electrical failure. I recently noticed my bikes radiator cooling fan was not running and coolant was overflowing from the radiator cap overflow. After diagnosing a bad thermo switch in the right radiator I decided to wire the fan via a hot wire from the positive battery terminal through a fuse and a toggle switch I mounted to the headlight shell I grounded the circuit to the lower speedo mount on the upper triple clamp. See pic. So far its a fix. No boil overs yet. I run the fan once the engine is warm and only shut it off at highway speeds. I've heard these big bore KTM engines run hot at low trail speeds especially on hot days. I've also heard talk of people deleting their coolant thermostat. Does anyone here have any input on thermostat removal on these bikes.I would never remove a thermostat from a car. I have ordered a 4" universal puller fan from Summit Racing USA to mount on the left radiator. I will wire it in series with the stock right side fan. Its only May and a cool one at that. Soon I will be riding In the triple digits. most of my riding is on pretty fast trails I do from time to time get stuck in slow traffic leaving town. This is how my last boil over occurred and I'm not sure if it would have happened had the fan been functioning.
