Thanks. Where is it? There are no wires coming from the clutch lever or reservoir. Is it on the slave?
Mike,Starts fine. Problem is it tries to start in gear with the clutch engaged so the bike lurches. Not supposed to do that. Not sure what else the gear position sensor impacts, but a bike with 20 hours on it should not be having this problem.
Didn't he say the clutch was "engaged"?
Am I way off here, but what's the problem? If the clutch is disengaged, then - I'd be looking at clutch drag. On my TE310 I soldered the clutch disconnect wires together so I could start while in gear like any other dirt bike.
I once had a bike slip off a narrow trail down a steep slope (just a foot or two, but no way could I get on or below the bike). Luckily for me, that pesky clutch safety switch had been bypassed and I was able to lean the bike toward me enough to hit the starter and starter drive that bugger back up onto the trail. (I would have been big-time screwed if that didn't work) That's a plus in my book...LOL...
Having to pull in the clutch to start the bike is mind-boggling to me. But what do I know?
Mike,
My 2012 TE 310 will also start when in gear with the clutch engaged. Had no idea that it should not do that. It would seem to be a drag to have to find neurral if you stall it. But this is my first estart dirt bike and I confess to being a neophyte on modern machines.
Best
Thanks! My misunderstanding and that is completely sensible.Nordic, you're misunderstanding... When the clutch is engaged, the lever is not pulled (i.e. if a gear is selected, an engaged clutch means the vehicle will move). If the lever is not pulled, you can't start by using the e-start. That is normal behaviour. There is a switch which allows starting when the clutch lever is pulled in, regardless of gear. Some people bypass this switch, so they don't have to pull in the lever to start. Mike-AK is saying his bike will start even if the bike is in gear and he doesn't pull in the clutch.
As far as I know all electric start bikes need the clutch pulled in to start.
"Pulled in" would be disengaged. You disengage the clutch to interrupt power to the drive wheel. And apparently all electric start bikes don't need the clutch pulled in (disengages) to start. Mine used to up until a couple days ago, but now if you hit the e-start button with the bike in gear and your hand off the clutch, it will lurch forward as the starter motor tries to propel it. Something has failed in order to make that happen, just as something has failed causing the low fuel light to come on regardless of how much gas is in the tank. The electrical systems are too complex on these FI bikes to be reliable. I'd gladly trade this low hour 2012 TE310 for a restored 430WR.
Which electric start bikes don't need the clutch pulled to start while the bike is in gear?
I think you are missing my point. This is the second random failure in the electrical system. What will the next one be? Will it kill the bike out in the bush and leave me stranded? Sorry...I'm just not seeing the quality in these Italian-made Husky's. Hopefully KTM will be able to finally do something with the brand.
