2011 TE449 Owner Observations
Thanks for the help guys. Since I weigh 275 without gear, should I try the 5.6kg rear spring or try the 5.4kg first?
Not going to be at Dezert Daze. I'm going to Ocotillo with some friends and family for St. Patty's weekend.
This is What I currently have with a Re valve set for 220 lbs plus gear.
Shock SR= 5.4 Sage 105MM Compression Low is out 11 clicks Compression High is out 1 1/2 Clicks Rebound 10 clicks.
Fork SR= .50 Preload 5MM. Compression Clicks out 10 Rebound Clicks out 14, 115cc of oil
Oil is 5wt.
Im 195 lbs and find the 54 spring works very well of me. Race sag 95mm, static sag 43mm
Hi Spud,
Just a passing comment.
IMO it appears to me that the 5.4 spring is actually too stiff for you based on those numbers.
At 195 lbs the perfect rate would have been 5.2 Kg, but as the standard spring is 5.1 Kg I would have thought that clickers would have been enough.
Of course this all depends on what type of riding you do and how fast you are !
SAM511
Hi Sam, im not a suspension expert so all im going to say is my suspension was setup by the uk husqvarna racing and it works very well.
Picked up the bike yesterday and rode it home 30 miles. Set the sag to 115mm since I wasn't wearing all my gear. Also dropped the forks down in the triples so they are even with the first line. It was at the second line initially. If I don't give it throttle, it tends to stall in 1st leaving from a stop. Played around in the Hasayampa riverbed for a few minutes. It is way too soft for going through whoops right now. I will do some more adjusting this weekend on my days off. I already ordered Touratech bar risers. I'm only 5' 11" and the bars seem too low. Thinking about a JD Tuner for the stalling issue.
