2010 te250 Oil Coming Out Of Airbox.
If his sight glass is having him put in 1100ml, it's too much.
Man, if the sight glass reading between the marks requires that much oil after all the stuff mentioned above either the measuring process is flawed or the bike isn't level laterally and/or longitudinally and showing an inaccurate reading. I get approximately 825 cc out of a fresh 1000cc jug after changing oil and filter with a warm engine. Not saying I am perfect by any means but something's not right to require 1100cc. Haven't had any swing arm stains yet with 100hrs on the clock.
I've found that the sump will not completely drain without removing the drain plug and screens and tipping the bike from side to side. A lot of additional oil will come out when you lean the bile over. Also, for the sight glass to be accurate, you need run the bike until warm and the let it sit for several minutes. BTW, my TE510 owners manual says 1.5 US Quarts for oil and filter replacement and 1.3 for just oil. That's a lot more than 900ml
My 09 TE510 says 1.5 for just engine oil and 1.8 qts. for oil and filter. I also shift the bike from side to side when changing the oil, I use 2 tie down straps 1 for each side makes the whole process easy. Level the bike,shift to the left, shift to the right, of course all plugs and screens are removed, which was made easier by using the 7602 drain set all are 14 milimeter.
Older TEs (09 & 10s) are a totally different Engine !
The new xlites hold 900ml +/- .
Personally I fill to 3/4 of sight glass with bike level, warm engine.
Never had any Oil "Stains" or problems .
