2010 husky TE 510 coughs and splutters on low revs ( intermittent )
david kerry
My husky will run normally but sometimes when i stop for a few mins , and get going again , it will cough and splutter on low to mid revs ( good at mid to high revs ). If i run a few kilometers it wont clear , but if i stop again for a few mins , it will run normally again ( can be hard to start ) and wont miss a beat all day . I dont ride hard and use 98 or 100 octane fuel always from same petrol company.
I have been advised by a friend who had similar problem on an earlier model a few years ago that it might be the Temperature Sensor . I think Husqvarna may have upgraded the sensor ( it was black and new ones are white ).
Any thoughts ????
Dave
When you stop for a few minutes, after riding, when you turn the key on, listen to the fuel pump to see if it sounds different from when it is cold, the priming sound. Fuel pump can slip up and out of the prefilter sock and get plastic bits inside and start to get gummed up.
For a couple of wiring issues that could cause your problems, see my blog, the last couple of pages I think
http://www.cafehusky.com/threads/dual-sporting-a-2010-te-450-with-cheap-tricks.15347/page-7
