can you answer these questions for me- so I/we know exactly what's going on at this point-
Symptoms:
When you- turn key ON- with Right hand switch ON (red button)
1- speedo does not cycle normally and show “normal screen”- (correct??) Y/N = No
2- the fuel pump did not cycle- (correct??) Y/N = No
3- the DC circuit (tail light/ odo/ euro minu headlight) is working-- (correct??) Y/N = Green power light, Rear and head lights work
4- Only the green light “neutral” on the speedo lights up, does it “just” light up and not blink- (correct??) Y/N = Not Neutral just the green run light
Also if you put the bike in gear does the light go off? = I will try when I get home
Then/ When you then hit the Right hand Switch starter button (black button)
1- Nothing happens- no click, does not turn over- (correct??) Y/N +nothing
Then/ When you kick the bike with kick start-
1- it does not start - (correct??) Y/N = No
2- the fuel pump does not prime- (correct??) Y/N = No
KNOWN-
1- battery is good (verified by testing)
2- Fuses are good (changed with new)
3- swiches were cleaned and are now dry
Awesome!! Congrats- told you that wiring looked like a rats nest and needed some workThey fixed it!
2 hours labor to find it. It was a crimped wire caused by bad factory cabling per tech! I have not picked it up but I will take a pic of what they found and post it up.
As for the pump the tech said they use hose clamps not safety wire.?
Thanks for all the help!
Blake
