I was not trying to be smart.
I guess two two wheel drive is not as good as two engings. Two engines would be like steering a scraper in the wet, power through the turn, yep yah! Get r done!
There was a shop bike ('13TXC310) sitting there with a stuck motor, so they swiped the drain plug off of it. Good as new.
Wait a minute----I thought that the '13 TXC 310 had a bottom mounted drain plug with no hose as opposed to the rear mounted '11-'12 TE and '12 TXC????
The drain plug on my '11 TE was super tight when it came back from the shop post-melt-down. I now ignore the manuals suggestion of "do not remove the hose"---I just loosen the hose, slide it off, and get the box end on the drain plug. I've done this ever since the first oil change where I left the hose on the drain plug the whole time and the plug staring to cross-thread during installation due to the sideways tension caused by the hose. The same day I ordered a spare drain plug.
The 2013s have the same Hose / Fitting arrangment AND a Magnetic Sump Plug .
So the 2013s can be drained via the sump plug, but you still need to remove the PITA fitting in order to clean the screen, correct?
