Xlite exhaust compatibility
Discussion in '4 Stroke' started by webski, Jan 8, 2017.
  1. webski Husqvarna
    Kansas
    83WR250-09TXC450-13WR250-09WR165
    KTM 200 XC - Honda XR 440
    Looking for an aftermarket exhaust for a 2014 TXC 250. When looking at FMF and Pro Circuit exhaust systems for the TXC 250/310 I only see them listed to 2012. Are they the same?
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    There is some differences between the headers for a TC vs. a TE I think. I believe the silencers can be made to fit without too much hand-waving (gotta remove the catalyst, IIRC). Also, they only use 1 spring, not 2 like the TE. The bottom line: TXC is like the TC I think.
    here's a good and cheap Ti silencer which might work (...and sell the new ECU that comes with it for $100-200 maybe) that BMP has on ebay:
    http://www.ebay.com/itm/322364688257?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
  3. Matthew525 Husqvarna
    New Berlin, WI
    2013 TXC 250R
    KTM 525, HONDA CRF150
    I have the 2013 txc 250 which is basically the same bike.
    The 2013-2014 txc 310 exhaust will fit. The 310 has a slightly taller cylinder, but the difference is small enough that you can make it work. I had to just slowly tighten all the bolts but it worked. I'd imagine manufacturing tolerances of the pipe might be more of a factor than 250 or 310 differneces to be honest.
    FMF 045543 is the pipe
    and 045526 for the header, but the header is pretty hard to find these days unfortunately.
