Hello All, first time posting so please be kind. Seeking some help with a 98 te 610 left kicker. I have a 92 wxe 350 as well which I restored a few years ago so very familiar with the 98 as it is nearly the same and shares many parts. I am restoring the 98 and she is almost done but I am getting water in the oil. I ordered all new seals, 3 for the water jacket, one for the cam, new cam bushing and the aluminum piece that houses the bushing and takes the o ring. The head gasket was replaced, surfaces cleaned, torqued properly. My question is this, on the water jacket that goes through the timing chain, the way I am installing it there is an o ring on the outer most face recessed half way in the engine, half way out to create the compression seal when housing is torqued on. The waterpump gasket's hole is smaller then the o ring and sits on top of it. This does not seem right to me, should I cut the gasket off on the lower part of water pump housing? My wxe 350 uses same gasket and water pump housing but does not have the removable water jacket and it's just a surface to surface seal and the gasket makes sense. Thanks, hope someone can help and hopefully I can help others in the future!
