Valve cover oil vent: Wobbly union?!
I'm working on one that fits a wide range of models but unfortunately I don't believe it will fit the newer 250/310 at this time. I'll look into it though.
If your in a rush to get one by next weekend or something, the ZipTy union mentioned on page 1 of this thread is made just for the newer 250/310 X-lite engines.
Silicone won't do the trick but this Seal-All stuff seems to be holding up well on my valve cover:
Exactly!
I've also found that RTV really doesn't work in this situation.
There was some kind of white RTV on mine (TE450 '06) when I got it and it started to weep a bit eventually. I ended up using Permatex Blue RTV (just so happens it goes with the blue and yellow plastics) and it seems to be working. Just gotta use the right amount. A little inside and coat it up outside and make sure you let it fully dry before heating up the motor or moving things.
