TXC 250 2013
Reegs
Hi
Bike runs great, however on last ride going up a hil in 3rd, bike revels out, not drive, had to push up hill, in 1st gear, let clutch out ( hydrolic ) and no drive revels out, cooled down and then rode and changed gears fine any idea ?
Not sure what you mean by revels out, since the word revel means "to take great pleasure in something, or to celebrate noisily and festively". Perhaps you meant "rev". So if the bike is revving without accelerating, it sounds like your clutch is slipping, which means that it be out of adjustment or the clutch plates are worn.
Hi, yes I ment reving out, unusual as the bike hasn’t done much work at all. How can you adjust a Hydrolic clutch ? Cheers
Maybe there is no adjustment on that particular model. on my 2017 FE 501 there is a screw that adjusts engagement point on the lever. Maybe your clutch plates are worn. The clutch should not engage when the lever is almost all the way out though. Other than worn plates, check to make sure that the clutch fluid is nice and fresh and filled to the proper level.
