Could anyone tell me what are these 2 are for. I'm not sure if they are supposed to be connected. And what are they for.
Ive just figured it out what it is. But its not connected. Could someone shed some light on were it connects to?
It's probably a spoofer to trick the computer into thinking that its colder outside than it actually is. These bike run horribly lean from the factory, so there are all kinds of gadgets available to richen up the mixture so that the bike doesn't stall off idle. It's actually a pretty big safety concern, because if the bike stalls on the street, someone could be killed or injured.
What you have there is a valuable piece of equipment. It is a booster plug and solves the problem of cutting out at low revs. Makes the bike pull away smoothly without having to rev and slip the clutch. There is a thread on the forum on how to fit it. Drill a hole in the bottom of the airbox just big enough to squeeze the brass coloured sensor in.
