Duncan_Idaho
Hi everyone,
I own a 2011 Husqvarna TE630 Enduro and I need some advice from owners who have experience with different sidestands fitted to this model.
My motorcycle has already fallen over while parked on its sidestand. The problem is the geometry of the stand currently fitted to the bike: when deployed, the foot lands much too far underneath the motorcycle, leaving the bike unstable.
In my opinion, the original design is seriously flawed.
I would like to move the actual ground contact point significantly farther outboard and, if possible, slightly farther rearward.
I have attached several photographs of the sidestand currently fitted to my bike.
I have two questions:
1. Is the sidestand currently fitted to my TE630 the original factory-fitted part?
Can anyone identify it from the photographs, including its shape, construction and any visible markings?
I would particularly appreciate confirmation from someone familiar with the original 2011 TE630 sidestand.
2. Which sidestand would you recommend as a proper replacement?
I am looking for a proven solution that gives the motorcycle a stable parking position.
I have read the Café Husky discussions about Kenneth Webb's custom sidestand, including the modifications based on a steel TE610 sidestand.
I have also found a report of a 2011 TE630 fitted with a Ken Webb custom sidestand.
Can anyone confirm:
Whether the Ken Webb design was actually made to fit the TE630?
Whether it requires modifications to the original TE610 stand, or whether a specific TE630 version was produced?
Whether anyone has the dimensions, photographs or drawings of this stand?
Is there another aftermarket sidestand that genuinely solves the TE630's poor geometry?
Please note: I am NOT looking for a stronger mounting plate, a different footpeg bracket, or simply a larger sidestand foot.
The problem is the geometry of the sidestand itself. I need the entire leg to position its foot farther outboard and preferably a little farther rearward.
The current stand makes the motorcycle unstable and it has already fallen over. I do not want to buy another stand without knowing that its geometry is actually suitable for the TE630.
Any advice from experienced TE630 owners, especially those who have replaced the original aluminium sidestand, would be greatly appreciated.
Thank you!
Can anyone confirm:
Thank you!
