Hi, I’m Troy McClure, (not really), and you may remember me from such posts as “pulling cylinder head, advice?” or “15000 Km service, valve clearances, engine noise”
I checked valves and timing chain over the winter. This spring, it didn’t sound any better. After a couple short rides, the noise is now much worse. Here’s the video.
https://youtu.be/_grmfyYbVxg
It now sporadically makes loud knocking under decel too. She’s coming apart. I suspect crank or rod bearing, or a busted ring or piston. Going to document the tear down here for future reference and to help me remember how it all goes back together. Certainly going to have some questions as I get into it.
First, drained the oil.
Hmm. This does not look good.
Pulled the clutch side cover to get as much out as possible. Also removed the clutch at this point. Have a new bushing. Spring washers were done last fall. While the basket had lots of movement, no indication that it was hitting anything else in there. Right side screen was intact, and clean.
Pulled the oil pump apart. This does not look good either. Manual states I should have 0.1mm side clearance, this look like there was no clearance, or, the metal in the oil that was small enough to pass the pickup screens has done a number on it. The outter plate was nicley scored up too.
Next step, engine is coming out. Tank is off. Hint, it’s easier to disconnect the fuel hose from the throttle body than it is the tank/pump connection.
I started reading ahead in the repair manual. Looks like I should be able to get the engine out, head and cylinder off, with little effort. I’ll get a good look at the bore, piston, rings, piston pin, and a feel for the crank/rod bearing.
Then it’s on to splitting the cases. Going to be done so I can give everything inside a good cleanup and inspection.
Given that the crank is a 3 piece press fit, I’ll have to enlist some professional help to dismantle and replace the rod bearing.
I’ll post up pics and progress as I go. I’m hoping that whatever the problem is, is not terminal.
Plan B, I wonder if SWM has the Super Dual in production, and, what they would want for a new motor. Lol. Look forward to advise, criticism, suggestions, or comments as I go.
