tosaw;37425 said:Follow these instructions and remember that the passing light button is on the front of the left hand handlebar switch. Also, If I remember right the bike has to be running.
From xfool on TT...
1- With ignition off, hold down the MODE button.
2- Turn the ignition on and continue to hold the MODE button down until WS appears in the lower right hand corner of the display. If you release the MODE button at this point you will jump to step 8.
3- Continue to hold the MODE button and flash the passing light 5 times. Hitting the high beams 5 times also works but the passing light button is easier.
4- Release the MODE button, "0001" appears. This is the setup for a SM with 18" wheels
5- Hit the MODE button and "0002" appears. This is the setup for a TE with a 21" wheel.
6- Select 0001 or 0002 then hold down the MODE button until WS appears in the lower right of the display. Release the MODE button.
7- Press the MODE button to scroll through the settings for wheel size, tach pulses/engine rev, etc. If you hold the MODE button down the value entered for each setting will show up, but as far as I can tell there is no way to change them. Scroll through the settings. The last one is "max" and the next push of the MODE button will bump you out of the TE or SM mode selection part of the setup and put you at step 8.
husky666;37560 said:These were the instructions that I followed except for one thing,''The bike must be running".So when you turn the ignition on while holding the mode button you must start the bike and then flash the passing light 5 times.Now you see 0002 display so you release the mode button once and display reads 0001 for SM.I finally got it!
Thanks for the tips,![]()
Tiny;39191 said:This sound easy enough will it work on o6 model 610
I'm back; it's not working on the 630. The only thing I am able to do is switch the display between km/h and mph.
Are you positive? The gauge I got as a replacement is the same part number as the original.You cant switch it back and forth on the 630s.
I tried that, doesn't work. I can sure try again, though.Did you start the bike?
On the 610 it's this procedure:
0: place transmission in neutral.
1: zip-tie the clutch lever down, or grow a third arm
2: depress mode button, keep it depressed.
3: turn on the ignition
4: Start the engine
5: WS will appear at some point, it's probably already there by the time you've got the engine running.
6: press the "flash to pass" button 5 times
7: now you can release the mode button.. if you released it any time between steps 2 and 6 try again from the top.
