Hi all, I recently picked up a 2008 SM610. I love it so far but the turn signal switch is dead. Picked up some aftermarket switches to replace both switch housings but I need some help with the wiring. Does anyone have some sort of diagram or anything for BOTH the stock left hand and right hand switches? Thank you!
I took the stock horn and indicator switches out of the housing on my 630. Not to difficult just small parts and hard to manipulate with large fingers. Easy to clean with contact cleaner spray. After drying I wrapped it with 1 layer of electrical tape to keep the dust from accumulating again. 610 is probably the same.
Thanks for the suggestion, part inside is actually broken though. Hence why I'm replacing it and the need for the wiring diagram.
