Hi all, On my te630, the side stand moved a lot laterally, by unmounting the system I have found out the screw is not the original, to thin in diameter so the gap lead to this play... I bought the offical one but seems to short . Do I have to force the nut part into the first hole? thx
Mine is different, it has an allen head and sits recessed in the hole. Spring hanger is welded to frame above stand mount. The parts drawing don't match mine either.
I have searched a lot mais impossible to find one screw different from this one too short ! same screw (too short as well) on SWM parts.
If the new bolt does the job you can clean up threads and apply some thread locker such as locktite 262. This will lock bolt and negate need for lockwasher. 262 is higher strength than 242.
Not sure to understand. My "official" bolt is too short so i cannot screw a washer+nut on the other side, see pictures. Locktite 262 is like a glue and no need of nut?
Yes I meant to say locknut. Locktite will hold the bolt secure without locknut but can be removed with a bit of effort.
