or- wr- cr tank difference
patgas
is the or and wr tank the same 3 gallon tank in steel and is the cr one alliminuim,looking for tank for 79 or 390 and want to find out if any of others are same cheers,
OR and WR fuel tank is aluminum and are the same. The CR tank just has a smaller capacity then the OR and WR fuel tank.
At least for the 1983 models the xc has a larger tank and longer plastic stops so the forks don't hit it. I am pretty sure the wr also has the larger tank and am sure the cr has the smaller tank. It is not that easy to tell the difference from pictures from most angles. Using that information you could probably figure it out by going through the parts sheets available on this site.
Fran
gas filler location
the easiest way to tell the older or / wr tanks vs cr is the gas cap is in the center of the tank. cr tank cap is on the rh side cause tank is narrower.
husky john
husky john
The 1979/80 Auto has the small aluminum tank with RH side fill as well.
T
sorry guys
either i hav different tank,because my tank is steel and it has big ding on other side.i thought the or and wr use a 3 gallon steel tank and the cr uses ally one ?
Does your tank have the center fill? Steel? IF so , this is an OR / WR tank.
The picture you posted looks like the larger steel tank... More pics please.
T
yep
yes larger center fill,steel tank, i asume or wr are same tank yes? any others same of any other years cheers,looking at part numbers 80 cr,79 or wr,78 0r wr all same part number steel tank i asume.79 cr same as 80 wr,wre,acc wich must be ally tank ? strange findings,bit of useless info for you guys.
