D12
After buying my '86 430 AE I have wanted to put an oil filter and pump on it ever since seeing a thread on here where someone had done that. I have a couple technical questions about it. First what size and thread are the oil fill hole and oil drain hole? I was thinking of using these as the return and pick-up respectively.
Next the info I have says the light coils are 70 + 70 W, so there is 140W total supplied by 2 separate 70W coils correct? I have found a 12v, 60W motorcycle turbo scavenge pump that is quite small, several of them are 2 to 2.5gpm flow. I was thinking of using one of these powered from one of the 70W coils if possible, thoughts? I know the coils are AC, its not to hard to get or build a bridge rectifier (AC to DC converter) to swap to DC. Voltages were not listed so I am uncertain if I would get 12vdc out after converting from AC to DC, or if I would get like 30vdc and 70W would mean lower amperage. Does anyone have a little more info on the generator coils?
As for the filter I am thinking of using an orifice plate (See picture below) from work (for creating a differential for monitoring gas flow at wells and gas plants, something completely unrelated to bikes anyhow). They look like a washer basically, round with a hole in the middle and come in all sorts of sizes (Ours don't have the little handle life the picture though, and ours seems thicker). The thing I like about them is they are precise, outside and inside diameters are precise, as well as thickness and surface. The surface is very smooth great for making a seal. The hole in the middle I could weld a pipe nipple to for a screw on filter and for the returning oil and drill a hole somewhere around the edge of the "Washer" for the oil to enter the filter. I Googled it for those screw on filters, oil goes in on the outer holes and returns clean from the single center hole, I didn't know that until now (The more you know!). I like the ease of changing screw on filters, ease to find, cost and available sizes (I want a decent size one). Anyhow, that was the thoughts for that, no real questions, just my plan.
I think this setup should work, add extra oil to accommodate the filter and added equipment, as well so there is more so the pick-up doesn't take in air too frequently. Any info is helpful, the less unexpected problems the better!
