Nordisk rims
Wildebeest90210
I've got a set of Original rims from my 83 500cr. The front is cracked in one place. I'm having a clear out so the question is are they of any use or are they scrap?
i am sure it can be welded.... not good for a super cross triple jump....but no husky parts should be scrapped.
It might be seam separation from a direct hit. Rims like these are rolled, seam welded, then finish macines for roundness. The seam is welded about 50% or less with the weld zone central across the width of the rim. A coincidental impact at the seam will cause the unwelded ends to separate without affecting the weld or structural integrity of the rim
Just worried about embrittlement due to age/work hardening. I will post a pic with the rest of my stuff on classifieds. I don't know but I guess Nordisk stopped making rims years ago. Did they supply any other marques apart from Husky?
Tie some fencing wire around those rims and twitch it up tight or the weld will come undone.
Fine with the wheel laced up but they will explode if left bare for any length of time.
dukkman, you are so right. I found my 430 rim separated on the garage floor today. I'd cut the spokes out a couple of months ago and was preparing the rims and hubs for rebuilding. The front has been sitting doing nothing and must have separated in the past couple of weeks. Looks just like your picture, as if someone put a very straight saw blade through it.
Can it be easily welded up again?
I have not let the crack or place that never was welded bother me. I do not have but a couple of rims without spokes and none have broken apart. I like the Nordisk rims because they are dated and say made in Norway. Whether I would repair or buy another rim, probably buy a new one how much is a rim now $175?
My guess is they are electron beam, plasma or perhaps resistance welded. It is most likely extruded class of aluminum as opposed to cast which will tig weld nicely probably preheat advisable. As for the results, I would expect those are heat treated, It won't be like new. I would want to fixture the rim with the gap closed (maybe not fully together) up as opposed to forcing the ends together, tacking and then welding so the tacks do not give way.
I feel that a suitable replacement for Nordisk is the Sun rims that Buchanan's sell.
Have worked with resistance welding previously, the 50% central weld I previously mentioned about is a characteristic of that process
DO NOT weld anything structural aluminum (like a rim) unless you have it re-heat treated. Welding removes any heat treating and makes aluminum as soft and weak as butter. You are far better off with a cracked but still heat treated Nordisk rim than welding one. Cracked Nordisks are common, all of mine are cracked and I do not give it a second thought.
