I wrote in a previous carb conversion post "My bike will stall if I ask it to pull from idle with no throttle. No throttle opening - no go. POP - stop. Turn the throttle a bit and it will lug down. Turn the idle screw in another half turn and it will mask this but it is there. Idle is idle and it does not make any power at the zero throttle point."
I believed this was deliberate leanout of the idle and off-idle fuel curve - probably to reduce fuel load to the catalytic element at idle. This probably is not true.
Yesterday I decided to misadjust my throttle position (using the hard stop) to replicate the flameout issue that is plaguing some of our members.
I first took a start point. With the engine cold and the battery held at 14.0Vdc (external power supply) my TPS wiper voltage was 995.1mVdc (black to orange/black on the throttle body electrical plug), my WFO (wide full open) voltage was 4.385Vdc. My reference voltage (orange) was 5.049Vdc
With 3 turns out on the idle screw my 09 TE510 would idle at 1850-1950. I feel this start point is a good one because I trust the Ibeat setup from the dealer, the bike idled at 1650 rpm with the 02 sensor in, and the bike acted very consistently. All my observations are with the full Power up Kit installed and no spark arrester in place.
Once the side cover was off the thottle body (the side with the cables and pulley) and I could manipulate the throttle shaft by hand a couple of things were obvious.
1) there is a flat spot right off idle. When slowly moving from idle to 3K rpm it is a blubbering point -when snapping the throttle open it is a bog-recovery spot if you start at that blubbering point. (much as if the accelerator pump shooters where too large on Holley automotive race carb)
2) by propping open the throttle idle point (I used a feeler gauges) this rich spot became wider and I could consistently replicate the flameout with the bike on the stand and in first gear. I minimized the test because I don't think my cam chain appreciated POP-bang-stop too much and it was obvious I was going the wrong way with the throttle plate. Idle at this point was about 2000 rpm with idle screw remaining at 3 turns out. Turning the screw in half a turn helped slightly and brought the rpm up to 2100 or so.
3) closing the throttle plate (by turning out the throttle plate hard stop) improved the throttle response. The action was noticeably smoother rpm increase in slow throttle movement, and quicker rpm increase with quick throttle movements. I backed out the screw until it idled at 1650 rpm with 3 turns out on the idle adjust screw. TPS wiper voltage was 949.0mVdc (hot engine) with battery 14.0Vdc.
I buttoned it up and went for a mixed ride. I deliberately fully closed/snapped open the throttle on slow uphill gnarly sections - lugged around (chain snatching the whole bit) some single track -maneuvered around at idle with no throttle (ashphalt).
The bike is snapper at low rpm and lugs about like 500cc is expected to. Backfiring on deceleration not increased. Gentle small throttle movements are more linear. Throttle action above 2500rpm is unchanged. I'd say my clutching in tight stuff is reduced 80%. Small movements (1/8 turn) of the idle speed screw makes a noticeable difference in crispness of throttle response.
One downside is the bike is more apt to bite in tight stuff - when you snap the throttle it will leap wherever it is pointing - and if there are some roots in the mix it will carry the wheel very easily. Bike reacts like it is lighter than it really is. (No joke)
On the trail I backed the throttle body idle stop position screw out until it had no more tension - then in 1/4 turn. This insures the throttle plate is being held open at it's fully closed position.
The bike changed very little from before - Idle is 1650-1700rpm with the idle screw 2 7/8 turns out - starts in gear with a tap of the button - lugs around parking lot-style with no throttle - very linear slow movement throttle response, very snappy quick throttle response.
I will leave it like this until it is time for a Ibeat calibration - then I will increase the position to the original wiper voltage value before the test. I will also not use the 02 sensor at this new setting. I believe the computer takes an offset based on operating conditions with the 02 sensor in. I don't want that to happen with this out-of-specification TPS setting.
I didn't have a flameout problem - but my clutch hand is very happy with the results of this tweak. Bike is much more responsive and fun to ride.
Works for me!
MAT
Works for me!
MAT
, I will certainly have a better idea after this weekend but I think I am going to have an even better time. I encourage everyone to check this adjustment- I brought this up in a couple circles and everyone kept saying it shouldn't matter because the bypass makes up for it- well- its not meant to make up for being WAY OFF... I think 3 turns is way off- and if anyone elses bike idles at 1850 at 4 turns you should check this out- not all will be off but I was surprised this is not part of normal I/beat calibrations- but once its set it should be good.
