Mold Release Cleaning Agent??
Discussion in 'Seat Concepts' started by withiam, Apr 2, 2012.
  1. withiam Husqvarna
    NY
    2009 SM610
    Hypermotard 1100 EVO; KLX250SF
    Getting ready to install my foam and seat cover. What do you recommend to clean the mold release off the foam?
  2. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    Why bother? You're covering it.
  3. withiam Husqvarna
    NY
    2009 SM610
    Need to remove the mold release so the spray adhesive will adhere.
  4. I was wondering the same thing, I just used some windex.
  5. Ruffus Husqvarna
    Usually just dish soap & water. Where I worked, our mold release agent was a watered down silicone spray. Was pretty universal in the rubber product's industry.
  6. withiam Husqvarna
    NY
    2009 SM610
    I asked Seat Concepts, "What should I use to remove the mold release from the foam? I tried Dawn dish soap but the foam is still slippery. Is that normal?"
    They answered, "You can use brake cleaner, acetone or so on as long you put it on a rag and then wipe it down."
    I stated, "Wasn't sure how aggressive I could get with the chemicals. Should it not be slippery when finished?"
    They answered, "It will be smooth, just not greasy."
  7. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    Would suggest TSP [tri sodium phospate]from the hardware store paint dept.
    It's used to clean surfaces pre-paint, not too nasty to use as it is water based and not volatile.
  8. huskyouwanna Husqvarna
    Woodend, Victoria, Australia
    95 WR360
    85&86 CR500, 86 KTM MX500, 87 KX500
    mentholated spirits
