As the title says - had the bolts come loose in my upper timing chain (cam gear) gear - bending the gear in the process while causing general badness inside my engine. Turns out Husky no longer makes the part (part number 8000 76461). I know that all 410's from '97 until 2000 use the same gear...not sure about years outside of that. If you have one, or know of anyone breaking a 410 engine, please let me know. This upper timing chain gear or camshaft gear is the last piece I need to put the engine back together. Thanks in advance, Squish
