salty_monk
I have a safari tank fitted (not sure if that makes a difference).
When I ran out of gas yesterday.. (incidentally it was right around 300 miles of mostly freeway with the safari tank although I could still see about half a gallon in the left wing of the tank) the warning light stayed off. I know the light works as it comes on when the gauge sets up.
Is it normal with the safari tanks (i.e. is the sensor deleted when you fit one) or is there a sensor on the fuel pump that might have gone bad?
I'm going to be in there anyway as I'm going to do the elbow upgrade & run some dry release couplings in the fuel pipes so figured I'd sort that out & put a new O ring in whilst I'm in there... Any help appreciated
