Hi everybody,
After an attempt to start my bike in cold weather and low battery, bike is stuck with the message EWS on the dashboard.
I pass the first details of the diag but relays, fuses, antenna ring OK and bought a new battery.
I have a K+DCAN OBD USB cable and Rheingold ISTA/D, ISTA/P and other standard bmw tools.
With ISTA/D I was able to recover the error codes that were:
009324 KOMBI: Undertension ==> Corresponds to the low voltage of the battery at the time of the worries.
I was able to erase the error codes and none returned. I first thought (not excluded yet) that the DME had taken a blow of juice apparently possible when we insist on the starter. But I can enter functional test of the DME in Ista is ok.
Wanting to see the info of the keys I launched ISTA/P and after scan I get the message. "Problem with EWS. (KOMBI) is not configured correctly (No key has been learned) It is therefore not possible to guarantee correct processing with ISTA/P. Contact BMW Motorrad for further information)
I read on other threat that keys data are stored in Dash: 25L160. I will dump the eeprom to see if it seems ok.
Is there any other software I can use to find info about EWS and keys? In ista/d there is nothing related to EWS, is it normal. If there is indeed an issue in the dash, What is the procedure to replace it?
PS: Another rider has a similar problem with the same motorcycle and took him to the Husqy / KTM concess. Their answer: We will change the DME but we are not sure, it will cost 1200 € and 10 weeks of waiting. In Rennes were i live BMW says "Not our Problem".
KTM says: "We cant help you"
Husky says: "We can't help you"
Sorry for long story and thank you for your help
