mr_extreme112
Hello,
how do you seperate the Cartridge from the Cartridge head to acces the Midvalve? I dont see any peens as there are on many other OC forks, do i just need to build a cartridge holding tool and use a screwdriver or punch to screw the cartridge head with some heat?
Did someone Revalve these forks? They ride to low in the stroke and deflect on big hits, im not really happy with the stock valving. I would try removing some rebound face shims and maybe a smaller Clamp shim on the BV, had good luck on other forks doing that. Maybe some face shims on the BV too? I dont want them to be too soft as i ride some faster stuff most of the time. I still prefer a slightly softer than usual setting for some 2-3h enduros.
