Carsondriver
Forgive the ignorance, but where to I access the screw to adjust down the idle on a te 630/.. thanks
I agree. If I turn it down too low the engine starts to clatter, almost like knocking/lugging. It doesn't sound like the valve noise you typically hear.A bit higher at 1650-1750 keeps the oil pressure up, assists starting, improves cooling while idling, and helps reduce excess 4-stroke decelleration. The smaller CC bikes are set for about 1900-1950, same reasons.
The bike idles significantly higher and significantly smoother once the PU kid is installed.After doing the PU mod (plug and resister) I take it you have to adjust the idle down correct??
BTW, where do you buy the resister? Is this something you modify with current one you have??
Could they have made this less accessible if they tried? F*** me.
