Hi Gang- Hoping someone can help here- I’m dim-witted on all things electrical. Replacing my rear signals (630) with an aftermarket set (traditional lights- not LED.) So here are the Q’s: 1.) You see the big connector- tail/brake light. 2.) Two smaller sort of rectangular connectors- each one to a turn signal. 3.) The aftermarket lights have two wires that’ll of course mate to the two wires at the connectors. On the aftermarket lights one is black and the other black/white. As you see on one connector there’s a red wire and a blue, and the other connector has two blue wires. How to know which I connect a black to and the other the black/white to...especially when they’re different? The red wire is rubbed through- explains why that signal didn’t work. I got aftermarkets b/c the stalks of the OEM’s were toast- broken. The new ones are shorter and sturdier. Thanks for your input and patience!
