So my headlight indicator has been sorta, iffy. It is on, then it might go out, wink a bit, on, off. Then just a solid on for a good ride. Then my contrast on the display was wonky and I figured water damage. Opened it up, siliconed it, dried it out. Works perfect. I though the LED for the headlight being "on" would perform normal now. Nope. All the connectors have dielectric grease now. Not related to the cluster. Cluster works great and is bone dry now. So there must be a wiring issue feeding the LED in the cluster. This is a North American bike with auto lamp on, and a blanked out switch. Should I pull apart the left handle bar "lack of switch" and see if there is an issue inside there or has this been addressed before here?
