FE/FC Fx Intake Tube In A 2017 Fe350?
Discussion in '4st' started by Lorne D, Oct 14, 2019.
  1. Lorne D Husqvarna
    CT
    2019 TE 300 TPI
    2017 FE 350, 2018 TX 300
    I just picked up a 2017 FE 350 and it needs some help. I intend to buy Slavens' Vortex ECU and emissions delete to go with a Rocket exhaust that I'm going to have modified to fit. I'm not too thrilled with the idea of reeds on my intake just for the sake of quieting, but I've seen where the reeds can be removed and some add an intake tube to hold the boot open. I'd rather just put a boot from an FX if it will fit. They use the same airbox, so I don't think it'll be a problem. Has anyone done this yet?
  2. longdrive Husqvarna
    09 TE 450
    06 RM 250 (295)
    Not sure what your outcome was since it was a few months ago, but I did it on a 18 501fe. Just swapped the intake boots and it worked. I believe I had to drill out screw holes for the sensor, but not big deal. Used wood screws and no problems yet.
    Let me know what you did.
  3. Lorne D Husqvarna
    CT
    2019 TE 300 TPI
    I used an FX airbox. I used some of the KTM screws that are used on a fuel tank after hogging out the holes for the bushing insert. Fits perfectly, no reeds! I also found an extra filter cage from one of the 300s that doesn't have a screen and I desmogged everything. I'm using the Slavens Vortex ECU. Now it runs like a race bike should.
    robertaccio likes this.
  4. Jorge Louis Husqvarna
    2018 FE350
    2008 CRF450X
    Yep, I put the FX intake on my 2018 FE350 and I can confirm it bolts right up. You will want to order the screws that Lorne D talks about above. They have a heavy thread for biting into plastic, not the machine thread found on the FE for the temp sensor. You will also need to decide where to route your valve cover vent hose, as the FX boot doesn't have an input for it. I routed mine to dump into the airbox, but you could probably just vent it to the atmosphere somewhere down low.
  5. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    That's why I used an FC intake boot on my 501.
