FE/FC FE501 Bumpstart Capacitor with Kickstart Kit
Discussion in '4st' started by Kawika B, May 29, 2022.
  1. Kawika B Husqvarna
    Te630
    Been trying to research this with little luck. FE 2017 501 does not have a bump start capacitor and I was considering adding one. However if the lithium battery goes completely dead as can happen with lithium, then it won't have enough juice to charge the capacitor correct? So, I was considering purchasing a kickstart kit. Does anyone know if the stator will charge a bumpstart capacitor when kickstarting?
  2. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    Slaven's racing has a video about it that might answer your question better than I can, but as I understand it the capacitor doesn't need to be charged as much as it needs to be there to remove voltage spikes that confuse the ECU.
    Link to video.
  3. MorrisBetter Husqvarna
    Nor Cal
    TE501s
    BMW R1200GS
    Carrying a spare battery is a simple solution. It doesn't take much of a lithium battery to start a motorcycle.
