Hey, I am moving from a 2011 TE310 that has been fantastic to a 2013 TXC310. I have a Leo Vince Titanium exhaust (slip on) that is still new in the box. Will that exhaust be OK on the TXC? The box states that it was for 2010 - 2012 year bikes, but is the flow ok for the 2013? Thanks!
I believe it should slip right on. The only difference exhaust-wise in the 2013 was at the header with the new Red Head. For reference, I checked with FMF and saw that their slip on mufflers are the exact same part number for 12 and 13.
When putting on a full exhaust do you need to re-map the bike? akrapovic says no, but thought I would ask you guys out there. Thanks Jim
Yes, stock the bikes are lean to begin with. Adding an exhaust only leans it out more. Depending on what year your bike is you have different options.
Yes, flashing a better map in the ECU will help. However, with a 2010 the Mikuni injection can be messaged using I beat.
There are several I Beat threads that would help you. Here's a search I did showing the wealth of info here on the Cafe. http://www.cafehusky.com/search/1477482/?q=Ibeat&o=date&c[node]=72
