Sorry, my mistake. I just realized that doesnt push as far in.I don't believe that will work on a 610.
If anyone see this in the future, I have the correct drill bit and tap to do the mod. Just PM me to borrow it.
Same boat here, 09 TE610. ZipTy has two different versions. My 09 required the more expensive one.
'09 610:
https://ziptyracing.com/products/gte-fi-husky
Nice, as is usual for ZTR. But I gotta ask: how is that new aluminum elbow retained in the fuel pump plate?
I don't know if you looked at the plastic elbow from Sherco in the other thread but it retails for £63.99 ($80) so you got off pretty easy.
Good question, I haven't started into it quite yet. There are some other threads about using channel-loc pliers and cantilever leverage. It seems you just have to force it out. I worry about the weird metal retaining washer in there...
no, I'm not asking about getting the plastic one out; I understand that. What I'm curious about is how the new aluminum elbow is retained once installed?
...maybe a metal spring clip? that is, if there is a groove on the female half I guess?
I just got the ZipTy replacement and it looks beautiful. I'll try to post pictures of the procedure, but it comes with a drill bit, tap and set screw (allen). After inserting it, you drill and tap the metal plate (outside the tank) on the raised collar, and insert the set screw. It says to use loctite, screw all the way in, then back out 1/2 turn.
...I also just saw the trick to getting the fuel lines off without spilling gas everywhere (small piece of fuel line connecting the two elbows). Wish I saw that earlier, I hate dealing with spilled gas.
I may replace the white elbow as well, just to be safe.
Success! I finally replaced the elbow with the fancy new CNC unit from ZipTy. I've gotta give them credit for making this piece and selling it for a reasonable price. They're certainly not in it for the money, but to help keep our Italian Huskys on the trail.
End result: Works perfect, no leaks, everything fit without any issues.
Here are a few photos of the process, took about 30m:
1) Original broken red elbow
2) Remove old broken elbow. I grabbed it with channel-lock pliers and tried to wiggle it out, and I knew this would happen - it broke off flush with the surface. I used a small pick to get the steel washer out, then a gentle pry with a flat head screwdriver pulled out the rest of the red plastic. I put a small sheet metal screw in the bottom just to 'plug it up' and not get any red plastic debris in there.
3) The new elbow requires a small hole drilled and tapped on the collar of the metal housing. I stuffed a paper towel in there to catch debris. Super easy, the elbow from ZipTy came with the drill bit, set screw and even the tap!
4) New elbow in place, fit perfectly, used maybe a little too much loctite but you can never be too safe
5) Time to mount it up. Hoses fit perfectly. It's a shame this is of sight, it's really a nice pice of CNC aluminum! It's going to take more than a tug on the fuel line to break this one!
Link to product:
https://ziptyracing.com/products/fuel-pump-elbow-oem-8000ah2930-gte-fi-husky
that's actually a pretty smart solution. cool. I guess that explains the cost too.
I don't know this technique (or really: I don't understand the problem). why would fuel come out? are you routing the fuel elbow into the return elbow or something?
btw, save the broken red elbow. then, if you or anybody else has another issue you can repair it and re-use it.
Link to product:
