Just installed a set of heated grips. Anyone know if the TE630 has a switched circuit suitable to power heated grips? I have them direct to the battery now, and already left them on by mistake. thanks.
I got 610 which is probably quite same as 630 on electricity. I took my relay trigger from the backlight since it were little easier to route. and the wires go near the battery to backlight. Placed my relay near the battery since there were enough space
Thanks guys. Think I'll pick up a relay and wire it in. A buddy just did his this way so he should be able to help sort out the wiring.
I had heated grips and used a FuzeBlocks relay. Worked well. I have now switched to heated gloves instead. Much less hassle to install - literally minutes for the outlet, no relay needed. A single outlet can be used for gloves and jacket. Easy to transfer the gear to other bikes (I have a variety of adapters for the power outlets). And the gloves heat the outside of my hand, where the cold wind blows. not just my palms.
