Hi Gang. Got a seeping base gasket, at rear of cylinder. Now if you'll recall this engine was dis/re-assembled by a well regarded Husky shop a few years ago to replace a cracked engine casing. That was around 7K ago. I noticed this at the beginning of last season, so it's been going on for about (rough estimate) 3K. At first I thought it was just dust collecting on residual stickiness, but cleaned it and what you see has developed over several thousand miles. This bums me as it's the start of this season and I don't wanna be without the bike (and no shop I trust for it anywhere near, by far.) I'm not confident enough in my skills to do this well (and haven't the best accommodations/tools to do so.) Bike runs well and has been. Is it possible to do a "watch and wait" thing- i.e. ride as long as I keep a close eye on it. Do they suddenly blow wide open and throw lots of oil, leading to sudden engine failure? I'd love to be able to eek one more season out, and then tackle this next off season (around Sept./Oct....about 2K miles out.) Thanks guys- here are the pics:
I would give it a solid clean and remove all residue. Ride it for a day and then make a call based on your own observations according to observed leaking from that day. personally I would ride it for the season it the blow through remained minimal.
Thanks man. That's what I'd decided early today- had a few hours to ride. Cleaned it up (what's in original pics is 2-3K "accumulation of blow-by and dust) and looked after the ride (only about 80 miles) a barely discernible amount, and it was ridden enthusiastically. I'll continue to keep an eye on it, and as a first step perhaps re-torque. Not likely to change anything but can't hurt. Was really wondering if they often eventually spew when they really go out (I.e. If I'm tempting worse issues if it pukes oil.) I don't think it often happens that way, given how often I've seen old seepage in cars and bikes. Here's today's before and after. Sorry they're upside down.
Thanks guys. Yes, I'd have to agree that a full on blow out would be unlikely, given the tight space between the base of the cylinder and the mating surface of the crankcase. I'll keep a close eye on it.
Oops- not sure how I overlooked that suggestion- thanks. Yes, I initially thought that was a possibility but upon close inspection that does not appear to be the case. The staining sure does suggest it as a possibility so right of you to point it out.
