630 won't start after I did the gas leak fix
Discussion in '610/630' started by tool46n2, Sep 6, 2015.
  1. tool46n2 Husqvarna
    Chicago
    I need some help diagnosing why my 630 wont start....here's the background.
    I experienced the standard tank leak like everyone else where it leaked from the fuel pump so removed, did the permatex thing. Put back together. Started right up...a week later started leaking again...took tank off and tired alot of permatex and let is cure for 24 hours and reinstalled. Now won't start.
    When taking the tank off the bike I couldn't get the main fuel line to disconnect from the fuel pump so I removed the other end from the throttle body. (just giving more info here)
    After it didn't start I took the tank off to diagnose and I removed the fuel line from the throttle body and there was significant pressure built up when I removed. There was fuel in that line when I removed so it looks like gas is getting to the throttle body.
    When I'm trying to start it it just keeps turning and turning but nothing.
    Any thoughts on what may be going on?
  2. Homerb Husqvarna
    Wyong Creek NSW
    Triumph Tiger 1050, KLX300, TT250,
    You haven't dislodged the coolant temp sensor on the back of the cylinder by any chance?
  3. tool46n2 Husqvarna
    Chicago
    Just checked and nope.
  4. Homerb Husqvarna
    Wyong Creek NSW
    Pull the plug, crank it over and check for spark.
    If you've got spark, I think there's an airlock in your fuel line somewhere.
    Can you disconnect the fuel line from the injector body, turn on the ignition, and make sure there's a solid fuel supply getting to the injector body?
  5. DYNOBOB Husqvarna
    Are you certain the fuel line is pushed on the fitting tight? Do you hear the pump prime when you turn the ignition on?
  6. tool46n2 Husqvarna
    Chicago
    I checked that it was on there tight but will make sure again...not sure about if the pump primed but will try when I get home tomorrow.
    Will also try to check for spark and check for good fuel supply
    Will let you know how these go.....thanks a bunch
  7. bmah Husqvarna
    Fuel pump installed upside down? The fuel pickup screen is upside down?
  8. radmann10 Husqvarna
    Husky 630
    KTM LC4, KTM 990 Adventure
    Did you get it to start? If so what was the issue? I also have a no start situation on a 630 and am trying to track it down.
