I'm looking for new spacers for my TE 630. Stock ones are worn too badly for the seals to do their job. Anyone find a source for these yet? Maybe from SWM? I had thought that they were available in kit form with bearings and seals? Any advice greatly appreciated as I'm good for now but need to replace them before I do the CBDR late summer.
Yes, I have the same problem except the CBDR timeline. I was looking for some made of stainless steel to last longer. The best I could find was anodized aluminum. Best supply seemed to be https://shop.enduroeng.com/cgi-bin/commerce.cgi?search=action&category=80HU
Thanks, I guess my search abilities aren't up to par. Forgot about that supplier. Still can't seem to locate the front spacers but I will continue on.
https://www.steahlyoffroad.com/drive-brake-wheel/wheel-bearing-spacers Even have some radiator guards for the 610/630, in Oregon. https://langsoffroad.com/products/wheel-spacers Looks like Front 16-084 and Rear 16-084. Canadian Enduro Engineering distributor, parts breakdown was easier to read. If you put those part numbers in the Enduro website search works out to about $30. I would double check they are correct part# for the bike. Also MX1 Canada is distributor.
Good information there, I currently away from home but will look into this when I get home for the weekend. Are you suggesting that you may have parts for sale?
I think the swm 650R ones will fit (i use my te250 wheels on the 650 and only have to swap the disk) , if you can give me the size of the te650 ones i can measure mine (650R)
