TE/TC 2017 300 Frayed Stator Wire
Discussion in '2st' started by KXcam22, Dec 16, 2017.
  1. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    Looks like Jeff Slavens was right. A quick look at my 2017 300 with 2.4 hours on it shows where the flywheel is wearing on the stator wire loom. Not good and something to fix. Hope this helps someone catch this before they have to Flywheel Mark s.JPG walk home. Cam
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    mine was the same did the slavens fix with 1 extra gasket and a good glob of 2 part epoxy and a c clamp to form it against the case. this was in the last spring when i got the thing
  3. KXcam22 Husqvarna
    Is the extra gasket worth putting on? Cam.
  4. robertaccio Husqvarna
    San Diego, Ca
    I just did it for extra insurance., never pulled it since installation.
    using epoxy and clamp until hardening to keep the wire bundle flat against the case will probably be all you need. you can see it hits but very slightly
  5. KXcam22 Husqvarna
    I used shoe goo since it is flexible an squashed the wire bundle flat. Dealer was closed so no extra gasket. Went for a short ride in the snow and will check today. Gasket adds 0.020". Cam
