2013 TE310R Velocity stack
Discussion in '4 Stroke' started by Boogie, Feb 14, 2013.
  1. Boogie Husqvarna
    Australia
    Red head
    Test rode, back to back, a Husaberg FE350 and TE310R... One had more fun factor than the other so I picked up the new husky last week. :thumbsup:
    The dealer de-restricted the bike and the velocity stack (red trumpet in air intake) was in the box of bits and not installed on the bike.
    What do you guys think?
    Is this a performance item or just a fancy restrictor?
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Performance, use it.
  3. Boogie Husqvarna
    Australia
    Red head
    Yep, thats what I'm thinking... in it goes.
  4. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    My '11 has one are these standard? Or was it part of a tc mod on older bikes?
  5. Boogie Husqvarna
    Australia
    Red head
    Not sure, I thought they were new for the 2013 TE's with the red head
  6. rockdancer Husqvarna
    mine has a tc air box - must be a 2012 tc box
    I thought this stack must be the main part of the tc power upgrade as air box Iooks similar
    Looks cool too
  7. honda4oo Husqvarna
    canada
    do you have a pic (red trumpet in air intake) the end of it has a bunch of little holes in it ,I don't see how
    that set up will let the te 310 r breath .other than to pass emissions
  8. Ex HVUK Husqvarna
    England
    None
    The 2013 TE310R comes with a restricted trumpet fitted (the one with the small holes in the end) and a full power version in the build box which comes with the bike. The dealer should replace the restricted one with the full power one when doing the power up so if you've got the one with small holes in then all is OK. If you've got the fully open one then it needs changing.
    Dave
    MikeB likes this.
  9. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    Ducati Sport Classic / Ducati Multi.
    Interresting.... No stack in my parts bag so maybe USA owners need to purchase the de-restricted stack. Dealer did swap the filter holder for the unrestricted one. All the intake stuff probably helps pass the noise limits re: intake drone as well as stealing some performance.
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    ^^^ What he said. I apologize if I offered incorrect advice earlier, I assumed it was no stack versus adding a stack which would increase performance. :o
  11. Ex HVUK Husqvarna
    England
    None
    Or your dealer threw the restricted one away? It's of no use...
    Dave
  12. honda4oo Husqvarna
    canada
    .is there a .02 senser deletor the same as the 2011 power up kit
    because my 2013 te .has no balls at all
  13. Ex HVUK Husqvarna
    England
    None
    No resistor required, full power is achieved with software reflash of ECU plus the removal of exhaust cat and airbox trumpet. This is for EU bikes, US may be slightly different. Need to confirm with your dealer what they have done.
    Dave
  14. rockdancer Husqvarna
    This must be the unresticted one
  15. honda4oo Husqvarna
    canada
    take a look at the other end of the stack that's were the little holes are
    on my te 310r I think its the restricted one
    good info on the above posts
    Huskyfly likes this.
  16. honda4oo Husqvarna
    canada
    what do you do with the 02 sensor in the head pipe ,my local dealer here hasn't a clue on what to do
    lets say that you want the put on a 2012 tc250 full exhaust
    thanks kim
  17. Boogie Husqvarna
    Australia
    Red head
    All good... It's not in the bike yet.
    Mine is the restricted one with many little holes, so makes sense for the dealer to remove. There isn't a full power version in the box or bike.
    I could:
    1. Leave the bike the way it is (no velocity stack)
    2. Modify the restricted one to open it up fully and install.
    The bike rips now, but I might install just for some internal bling and maybe a power gain.
    Question: would the stack help more in high or low RPM?
    Will post pics when I get a chance.
  18. mike_21 Husqvarna
    2013 TE 310R
    Ducati 1098S Track Only
    My dealer took the restrictor plate out and cut the center portion out creating a 100% pass thru. Maybe they don't send the unrestricted component to US bike but he took care of it for me. Bike runs great.
  19. Ex HVUK Husqvarna
    England
    None
    Just take it out and disconnect, once the software is updated the O2 sensor isn't required.
    Dave
  20. Boogie Husqvarna
    Australia
    Red head
    FYI. Here's the bits removed: DB Killer, O2 sensor and velocity stack.
