125-200cc 2013 CR125 clutch
Discussion in '2 Stroke' started by splime738, Dec 15, 2019.
  1. splime738 Husqvarna
    UK
    2013 Husky CR 125
    various old 70's & 80's kx's
    I have a low hours 2013 CR125, when ridden hard or a lot of clutch use and I have to keep winding the adjuster as it looses feel. I burnt the clutch out on it a while back so when I pulled it apart put a new basket in it along with all new plates steel and friction, New springs and a new husky cable but it still needs cable adjusting when used. I ride mainly older kx' s my most modern being a 89 KX125 and I never have to adjust anything on that or the older bikes. Done a few snotty 3 hour events with plenty of clutch abuse on the 89 and nothing alters on it. Is it a common thing with the Husky, I don't understand why, oil wise being in UK I use Putoline light gear oil as with the other bikes.
  2. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    My WR is the same way.
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    My 2013 doesn't seem to have any problems. I change the oil at least once a season, or whenever it gets dirty, and never seem to need to readjust the cable. I use Honda HP Transoil 80/85 wt. in all my two stroke engines. It is my favorite so far, after using a lot of other brands over the years.
  4. rancher1 Husqvarna
    WA
    Maybe try a good aftermarket cable, the stock one does stretch a bit.
  5. splime738 Husqvarna
    UK
    2013 Husky CR 125
    Thanks Rancher, yes will try ordering s venhill and see how I get on
