125-200cc 2012 Wr125 Countershaft Spacer
Discussion in '2 Stroke' started by gmoney1163, Oct 31, 2022.
  1. gmoney1163 Husqvarna
    Connecticut , USA
    2012 WR125
    Is there a counter shaft spacer that will work besides the OEM one part number 800031744 ? I can’t find the OEM anywhere they are all on back order .
  2. wallybean Mini-Sponsor
    Montana
    I looked for one for you. I actually can't believe I don't have a spare. Good luck, I expect you will just need to keep watching for parts on fleabay. You can also have a machinist build one for you. You will need the od of the output shaft and the size of the seal. He will also need to have at least a picture of the oem part so he can make the inlet surface where the o-ring sits and a slight bevel so it is easy to install into the seal.
