250-500cc 2011 WR300 Coolant in Combustion Chamber
Discussion in '2 Stroke' started by icebergstu, Jul 8, 2017.
  1. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Hi all,
    Over the last couple of weeks I've noticed a slight smell of coolant when riding.
    The bike had started losing/using coolant but I ride in very tough terrain and boil it quite often
    Bottom end has about 400 hrs on it and recently did a top end for only the second time.
    I have had broken O'Rings on the head before and assumed that this was the cause but when I took the head off today the outer was perfect and the inner seemed loose but still in tact.
    Last couple of times the inner was actually broken or perished which was an easy diagnosis.
    I Have heard that the impeller shaft can also be an issue but I can't see how it would let coolant into the crankcase.
    What are your suggestions? What else should I check?
    Gearbox oil is clean with no signs of milky love.
    This will give you a bit of an idea of my average ride.
    View: https://youtu.be/HffZwE1Cepc
    Stu
    Dirtdame likes this.
  2. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Oring for sure.
    Carbon near the journal's showing leakage.
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Cheap fix then mate, good stuff
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thicker o ring ?
    Or put the head on some 400grit sand paper and a glass then lap it in.
    NCSteve likes this.
  5. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    New O'Ring went in with a smear of hi-temp silicone.
    It retains the coolant in the radiators now...Bonus!!!
    And it's easy to start again.
    juicypips likes this.
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Living the dream Hope the fix lasts this time.
    icebergstu likes this.
