250-500cc 2010 WR250 jumping out of 2nd gear
Discussion in '2 Stroke' started by roj00, Mar 28, 2017.
  1. roj00 Husqvarna
    New Zealand
    2010 wr250
    Xr250, drz400 sm
    My 2010 wr250 has started to sometimes jump out of 2nd gear not every time but sometimes. It has only done 14 hours so surely it is not wear. Has anyone else had this problem?
  2. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    lankydoug, shawbagga and Eaglefreek like this.
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    I was thinkin this^, mine did it a while back but been fine since
  4. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    Well I also had this issue a few times, loosing second gear on my 2010 WR300. But it is pretty much not happening anymore. I related it to a slightly bent shift lever and that I wasn't moving the lever far enough to fully engage the next gear.
    Even so I can't wait to install the wide ratio gearbox and when I do I'll use loctite on this screw to be sure they doesn't come loose. I'll probably wait for the summer-break as this maintenance will take some more time as I will probably change all the lower end bearings, probably a new rod and maybe a new nikasil coating ...
    Cheers
  5. roj00 Husqvarna
    New Zealand
    2010 wr250
    Xr250, drz400 sm
    I pulled the clutch out of the bike to check the screw and sure enough it had back it self out 2 turns and the other 2 screws in that assembly were on there way out as well. Amazing that this happened at 19hours. Hopefully that sorts out the problem. Will up date after going for a ride in a couple of weeks.
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    How many hours on the engine? Crank, rod and cylinder looked brand new after 300+ hours on my 09 WR250.
    It seems the 2010s were the only bikes to have the shift drum screw come loose and most of them came loose early on.
  7. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    I put loctite 243 on mine before I even rode it as I had heard about this from the abovementioned thread!
    Have not had any probs with it since!
    Hopefully yours will be cured now to!
  8. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Another "Wine Wednesday" issue. Glad you caught it.
    SmokeyExpress likes this.
  9. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    My engine is also having +300hrs, not 100% sure because the previous owner didn't had an hour meter, maybe 400hrs in total, not bad for the first bottom end and cylinder, well even piston because I'm on the second 'B' still :rolleyes:
  10. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    The screw came loose on my 2011. I'm not sure on how many hours due to not having an hour meter, but my guess would be around the 50 hour mark.
  11. roj00 Husqvarna
    New Zealand
    2010 wr250
    Xr250, drz400 sm
    I went for a ride tonight and it is shifting like a champ, Thanks for you help guys
    lankydoug likes this.
