2010 Te 250 I Beat Help
Discussion in 'EFI/carb' started by Josh221, Apr 12, 2021.
  1. Josh221 Husqvarna
    2010 250 TE
    08 KTM 450 EXC-R, 07 HD Sporster
    What files do I need to get I beat up and going. Do I need to purchase this usb key for anything. Thanks
  2. kirbybikes Husqvarna
    All the info you need for getting Ibeat up and running, cables and programs are located in here. http://www.cafehusky.com/threads/the-ibeat-thread.44621/ Yes I know this is for the 630 but Ibeat is still the same. The settings for your TE 250 will be found else where. No you don't need the USB key.
  3. Josh221 Husqvarna
    2010 250 TE
    Thank you for putting me in the right direction. Where do you think I can find the TE 250 settings? On one of these threads on this site?
  4. kirbybikes Husqvarna
    Try in this thread, there are some numbers. At least a starting point. http://www.cafehusky.com/threads/up...-commander-to-the-new-12-hole-injector.42180/ Once you start riding you can adjust from there. You could also look at the power commander map for your bike and get an idea what they are doing with the fuel setting on how your setting should be adjusted. To find this thread I just scrolled thru about 10 pages looking for Ibeat info for a TE 250, try doing the same and see the settings others have used. My disclaimer I am not a Ibeat expert just trying to help a fellow rider out. I have had my bike 10 years now and am still messing with the fueling!
