2010 510smr Daily Rider
Discussion in '4 Stroke' started by Tech 3, Jun 22, 2011.
  1. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Just got a 2010 510smr Love this bike
    gonna do a few mods to make it what i want,
    here is a shot when i brought it home.
    Then did a exhaust mod,
    Opened up the cans Just removed the cats and the end silencer sounds sweet
    Then added my air fuel mixture gauge and a GPS
    And now for a body change new plastic from Husqvarna
    Ordered some new graphics from the UK not here yet
    The only thing more will need to be done is bring the air fuel ratio in line and we should
    be good to go.
    680 miles and two oil changes so far the only repair was fuel pump slipped up, had to
    tie it back down other than that perfect, valves so far right on.
    Pretty [IMG]
    Lookin good! Got any plans for graphics?
    I ordered a version of this one
    Getting Closer Blacked out exhaust and swing arm
    waiting for graphics from UK
    I like that. Powder coat on the swingarm and ceramic on the exhaust? Or high temp powder on the exhaust?
    How does your Air/fuel gauge work? Is it hooked up to a probe in the throttle body or something?
    sm2, pvduke and Mik-3 like this.
  2. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    It is a innovate motor sport LC-1 wide band O2 sensor that screw's into
    oxygen sensor bung where the original sensor went on the mid pipe
    look up innovate motor sports LC-1 it will tell you all about it
    we have been using this unit for about 4 years to set up carbs and tweak the F/I
  3. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Here is a shot of the LC-1 read out to give you a idea
    Mik-3 likes this.
  4. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    curious about the afr i went to the site but im not to educated in the tuning dept... what exactly can i do with this item if i just use the stock ecu no pcv vortex auto tune etc.? comparable to IBEAT? also which version are you using? the 199 version or the 329 version didnt know what the dif is... i have an 08 smr 450 thanks!
  5. Tech 3 Husqvarna
    Ohio
    2010 SMR510
  6. J.R. Husqvarna
    Northern Utah
    450 Supermoto! and a BUNCH 'O parts
    Tech 3,
    When you reply to someone's quote, make sure you reply after their quote, not in it. That way everyone knows what's goin on
  7. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    also did you purchase the 300 dollar one or the 199 one? thanks!
  8. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    JR sorry about the post in the quote
    B_M_F WE got ours a while ago but it would be the $199.00 one
    GO to E Bay they are on there for $150.00 and up
    If you need any help let me know
  9. guscycle Husqvarna
    Florida
    '99 Husky CR250, '07 Husky WR125,
    '10 Husky SMR450, '98 Husky Scooter
    I always wanted a 2010 SM 450/510R after seeing this one. wpid-Husqvarna_SM_450R_2010_18656.jpg I GOTTA GET ONE OF THESE![IMG]
    Have a good day,
    [IMG] Guscycle
    sm2, Tech 3 and Mik-3 like this.
  10. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    thats a 530r euro model you can get a 510rr or 450rr but not titled for streets.
    thanks i will order one asap im only getting 40 miles per stock tank on my 08 450 with pu kit any ideas?
  11. J.R. Husqvarna
    Northern Utah
    No prob man :thumbsup: just helping out.
    Husky made RR models 2006-09. '06-07 were the early generations and only a 450. '08-09 was the new generation with the 530 only available in '09. This was a worldwide thing... and there wasn't ever a 510RR. The one above is an '08 450. In 09, the RR's had white graphics. I kinda dig the black '08 graphics a bit mire than the white ones. Hope that clears things up :D I sure wouldn't mind a 450RR. A while back here in the states there were a few leftover 450 and 530RR's that came out of no where and sold for cheap. $8,000/$8,500 cheap.. I sure wish I had taken the chance to get one..
  12. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    B_M_F when you get the AFR gage you will be able to tell in what areas
    you might be running rich, you can lean out those rich area's for more MPG
    I did a 170 mile ride on my SMR the other day and i noticed that there were
    definitely spots that could be leaned out. I also have the PU kit I can go about
    60 miles be four i really need to find gas i run completely out at around 70 miles
    it happened during the 170 mile ride, my fuel light comes on at around 50 miles
    and it is best to start looking at that point.
    AND YES THAT RR IS SUPER SWEET I really like the black
  13. guscycle Husqvarna
    Florida
    ...stop it , you're killing me ![IMG]
  14. J.R. Husqvarna
    Northern Utah
    Your tellin me! :D
  15. Darkside Husqvarna
    SF Bay Area
    none left
    beta, ktm, aprilia
    What is the ideal A/F ratio for power?
  16. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    13.2 -13.4
  17. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    So far mine seems to make the most power around the 12.9 to 13.2 range
    but thats a guess (BUTT) Dyno, The bike just turned over 1000 miles
    gonna try to do some dyno runs next week and i will find out
  18. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Does any one know where you can get this plastic or the graphics
    or would would you have to have them made
    I like it better than the white my self
  19. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    i think a vinyl guy could do it up pretty cheap its just the side # plates and the rad shrouds.
    What fuel management are you using tech3?
  20. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    B_M_F I found the plastic and graphics
    as far as fuel management i will probably go with a PCV
